Delete an existing file or directory
Deletes an existing file or directory to remove unnecessary or outdated data from your system.
HTTP method and endpoint
DELETE /storage/volumes/{volume.uuid}/files/{path}
Introduced in
ONTAP 9.8
Usage notes
Query-based DELETE operations are not supported.
volume.uuid |
string |
path |
True |
Volume UUID |
path |
string |
path |
True |
The relative path of a directory in the volume. The path field requires using "%2E" to represent ".", "%2E%2E" to represent ".." and "%2F" to represent "/" for the path provided. Refer to "relative reference resolution" section in Getting started with the ONTAP REST API for considerations when using "..". |
recurse |
boolean |
query |
False |
Delete an entire directory. The behavior of this call is equivalent to rm -rf.
throttle_deletion |
integer |
query |
False |
The maximum number of directory delete operations per second. A valid throttle_deletion number is an integer from 10 to 100000. |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
131102 |
Read-only file system. |
131138 |
Directory not empty. |
918235 |
A volume with UUID {volume.uuid} was not found. |
6488081 |
The {field} field is not supported for DELETE operations. |
6488110 |
A volume delete is not supported on this endpoint. |
6684674 |
No such file or directory. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
