REST API reference
Deletes a core dump
DELETE /support/coredump/coredumps/{node.uuid}/{name}
Introduced In: 9.10
Deletes a core dump.
  • system node coredump delete
node.uuid
string
path
True
Node UUID
name
string
path
True
Core name
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
