Delete a core dump
Deletes a core dump to manage system storage and maintain optimal system performance.
HTTP method and endpoint
DELETE /support/coredump/coredumps/{node.uuid}/{name}
Introduced in
ONTAP 9.10
Related ONTAP commands
system node coredump delete
node.uuid |
string |
path |
True |
Node UUID |
name |
string |
path |
True |
Core name |
return_timeout |
integer |
query |
False |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
