REST API reference
Delete a core dump
Deletes a core dump to manage system storage and maintain optimal system performance.
HTTP method and endpoint
DELETE /support/coredump/coredumps/{node.uuid}/{name}
Introduced in
ONTAP 9.10
  • system node coredump delete
node.uuid
string
path
True
Node UUID
name
string
path
True
Core name
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Status: Default, Error
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
