Retrieve recent asynchronous jobs
Retrieves a list of ongoing asynchronous jobs to monitor their progress and outcomes. Once a job completes as either a success or failure, it remains available for a limited time before deletion.
HTTP method and endpoint
GET /cluster/jobs
Introduced in
ONTAP 9.6
Usage notes
Retrieves a list of recently running asynchronous jobs. After a job transitions to a failure or success state, it is deleted after a default time of 300 seconds.
node.name |
string |
query |
False |
Filter by node.name
state |
string |
query |
False |
Filter by state |
description |
string |
query |
False |
Filter by description |
error.arguments.message |
string |
query |
False |
Filter by error.arguments.message
error.arguments.code |
string |
query |
False |
Filter by error.arguments.code
error.target |
string |
query |
False |
Filter by error.target
error.code |
string |
query |
False |
Filter by error.code
error.message |
string |
query |
False |
Filter by error.message
code |
integer |
query |
False |
Filter by code |
uuid |
string |
query |
False |
Filter by uuid |
start_time |
string |
query |
False |
Filter by start_time |
message |
string |
query |
False |
Filter by message |
end_time |
string |
query |
False |
Filter by end_time |
svm.uuid |
string |
query |
False |
Filter by svm.uuid
svm.name |
string |
query |
False |
Filter by svm.name
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
records |
array[job] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"code": 0,
"description": "App Snapshot Job",
"end_time": "string",
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"message": "Complete: Successful",
"node": {
"name": "string"
"start_time": "string",
"state": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
The error that caused the job to fail. This property is only populated when the job fails and it matches the API response error structure used by all APIs. The message and code match the dedicated message and code properties once the job has failed.
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
node
The node where this job was run
name |
string |
The name of the node |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
job
_links |
code |
integer |
If the state indicates "failure", this is the final error code. |
description |
string |
The description of the job to help identify it independent of the UUID. |
end_time |
string |
The time the job ended. |
error |
The error that caused the job to fail. This property is only populated when the job fails and it matches the API response error structure used by all APIs. The message and code match the dedicated message and code properties once the job has failed. |
message |
string |
A message corresponding to the state of the job providing additional details about the current state. |
node |
The node where this job was run |
start_time |
string |
The time the job started. |
state |
string |
The state of the job. |
svm |
uuid |
string |
error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
