REST API reference
Retrieve recent asynchronous jobs
Obtains a list of recent asynchronous jobs, which helps you monitor ongoing processes and troubleshoot any job-related issues efficiently.
HTTP method and endpoint
GET /cluster/jobs
Introduced in
ONTAP 9.6
Usage notes
Retrieves a list of recently running asynchronous jobs. After a job transitions to a failure or success state, it is deleted after a default time of 300 seconds.
description
string
query
False
Filter by description
svm.name
string
query
False
Filter by svm.name
  • Introduced in: 9.8
svm.uuid
string
query
False
Filter by svm.uuid
end_time
string
query
False
Filter by end_time
error.arguments.code
string
query
False
Filter by error.arguments.code
  • Introduced in: 9.9
error.arguments.message
string
query
False
Filter by error.arguments.message
error.message
string
query
False
Filter by error.message
error.code
string
query
False
Filter by error.code
uuid
string
query
False
Filter by uuid
code
integer
query
False
Filter by code
state
string
query
False
Filter by state
message
string
query
False
Filter by message
node.name
string
query
False
Filter by node.name
  • Introduced in: 9.11
start_time
string
query
False
Filter by start_time
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[job]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "code": 0,
      "description": "App Snapshot Job",
      "end_time": "string",
      "error": {
        "arguments": [
            "code": "string",
            "message": "string"
        "code": "4",
        "message": "entry doesn't exist"
      "message": "Complete: Successful",
      "node": {
        "name": "string"
      "start_time": "string",
      "state": "string",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
code
string
Argument code
message
string
Message argument
error
The error that caused the job to fail. This property is only populated when the job fails and it matches the API response error structure used by all APIs. The message and code match the dedicated message and code properties once the job has failed.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
node
The node where this job was run
name
string
The name of the node
svm
_links
_links
name
string
uuid
string
job
_links
_links
code
integer
If the state indicates "failure", this is the final error code.
description
string
The description of the job to help identify it independent of the UUID.
end_time
string
The time the job ended.
error
error
message
string
A message corresponding to the state of the job providing additional details about the current state.
node
node
start_time
string
The time the job started.
state
string
The state of the job.
svm
svm
uuid
string
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
