Retrieve recent asynchronous jobs
Accesses a list of recent asynchronous jobs, helping you monitor and review ongoing processes.
HTTP method and endpoint
GET /cluster/jobs
Introduced in
ONTAP 9.6
Usage notes
Retrieves a list of recently running asynchronous jobs. After a job transitions to a failure or success state, it is deleted after a default time of 300 seconds.
code |
integer |
query |
False |
Filter by code |
error.code |
string |
query |
False |
Filter by error.code
error.arguments.code |
string |
query |
False |
Filter by error.arguments.code
error.arguments.message |
string |
query |
False |
Filter by error.arguments.message
error.message |
string |
query |
False |
Filter by error.message
svm.uuid |
string |
query |
False |
Filter by svm.uuid
svm.name |
string |
query |
False |
Filter by svm.name
uuid |
string |
query |
False |
Filter by uuid |
state |
string |
query |
False |
Filter by state |
description |
string |
query |
False |
Filter by description |
end_time |
string |
query |
False |
Filter by end_time |
start_time |
string |
query |
False |
Filter by start_time |
node.name |
string |
query |
False |
Filter by node.name
message |
string |
query |
False |
Filter by message |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[job] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"code": 0,
"description": "App Snapshot Job",
"end_time": "string",
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"message": "entry doesn't exist"
"message": "Complete: Successful",
"node": {
"name": "string"
"start_time": "string",
"state": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
The error that caused the job to fail. This property is only populated when the job fails and it matches the API response error structure used by all APIs. The message and code match the dedicated message and code properties once the job has failed.
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
node
The node where this job was run
name |
string |
The name of the node |
svm
_links |
name |
string |
uuid |
string |
job
_links |
code |
integer |
If the state indicates "failure", this is the final error code. |
description |
string |
The description of the job to help identify it independent of the UUID. |
end_time |
string |
The time the job ended. |
error |
The error that caused the job to fail. This property is only populated when the job fails and it matches the API response error structure used by all APIs. The message and code match the dedicated message and code properties once the job has failed. |
message |
string |
A message corresponding to the state of the job providing additional details about the current state. |
node |
The node where this job was run |
start_time |
string |
The time the job started. |
state |
string |
The state of the job. |
svm |
uuid |
string |
returned_error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
