REST API reference
Retrieves a list of recently running asynchronous jobs once a job transitions to a failure or success state, it is deleted after a default time of 300 seconds
GET /cluster/jobs
Retrieves a list of recently running asynchronous jobs. Once a job transitions to a failure or success state, it is deleted after a default time of 300 seconds.
Learn more
end_time
string
query
False
Filter by end_time
description
string
query
False
Filter by description
message
string
query
False
Filter by message
state
string
query
False
Filter by state
start_time
string
query
False
Filter by start_time
uuid
string
query
False
Filter by uuid
code
integer
query
False
Filter by code
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
return_timeout
integer
query
False
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
records
array[job]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "code": 0,
      "description": "App Snapshot Job",
      "end_time": "string",
      "message": "Complete: Successful",
      "start_time": "string",
      "state": "string",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
job
_links
_links
code
integer
If the state indicates "failure", this is the final error code.
description
string
The description of the job to help identify it independent of the UUID.
end_time
string
The time the job ended.
message
string
A message corresponding to the state of the job providing additional details about the current state.
start_time
string
The time the job started.
state
string
The state of the job.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
