Retrieve recent asynchronous jobs
GET /cluster/jobs
Retrieves a list of recently running asynchronous jobs. After a job transitions to a failure or success state, it is deleted after a default time of 300 seconds.
Learn more
start_time |
string |
query |
False |
Filter by start_time |
state |
string |
query |
False |
Filter by state |
description |
string |
query |
False |
Filter by description |
message |
string |
query |
False |
Filter by message |
end_time |
string |
query |
False |
Filter by end_time |
uuid |
string |
query |
False |
Filter by uuid |
code |
integer |
query |
False |
Filter by code |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
records |
array[job] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"code": 0,
"description": "App Snapshot Job",
"end_time": "string",
"message": "Complete: Successful",
"start_time": "string",
"state": "string",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
job
_links |
code |
integer |
If the state indicates "failure", this is the final error code. |
description |
string |
The description of the job to help identify it independent of the UUID. |
end_time |
string |
The time the job ended. |
message |
string |
A message corresponding to the state of the job providing additional details about the current state. |
start_time |
string |
The time the job started. |
state |
string |
The state of the job. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
