REST API reference
Retrieve interconnect adapter information for nodes in MetroCluster
Retrieves interconnect adapter information for nodes in a MetroCluster, helping you understand the connectivity configuration between these nodes.
HTTP method and endpoint
GET /cluster/metrocluster/interconnects
Introduced in
ONTAP 9.8
Usage notes
Retrieves a list of interconnect adapter information for nodes in the MetroCluster.
  • metrocluster interconnect show
partner_type
string
query
False
Filter by partner_type
adapter
string
query
False
Filter by adapter
vlan_id
integer
query
False
Filter by vlan_id
  • Introduced in: 9.9
  • Max value: 4095
  • Min value: 10
type
string
query
False
Filter by type
multipath_policy
string
query
False
Filter by multipath_policy
  • Introduced in: 9.11
mirror.state
string
query
False
Filter by mirror.state
mirror.enabled
boolean
query
False
Filter by mirror.enabled
state
string
query
False
Filter by state
node.uuid
string
query
False
Filter by node.uuid
node.name
string
query
False
Filter by node.name
interfaces.gateway
string
query
False
Filter by interfaces.gateway
interfaces.netmask
string
query
False
Filter by interfaces.netmask
interfaces.address
string
query
False
Filter by interfaces.address
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[metrocluster_interconnect]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "adapter": "string",
      "interfaces": [
          "address": "10.10.10.7",
          "gateway": "10.1.1.1",
          "netmask": "24"
      "mirror": {
        "state": "string"
      "multipath_policy": "string",
      "node": {
        "name": "node1",
      "partner_type": "string",
      "state": "string",
      "type": "string",
      "vlan_id": 0
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
2427132
MetroCluster is not configured on this cluster.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
interfaces
Object to setup an interface along with its default router.
address
string
IPv4 or IPv6 address
gateway
string
The IPv4 or IPv6 address of the default router.
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
mirror
enabled
boolean
Specifies the administrative state of the NVRAM mirror between partner nodes.
state
string
Specifies the operational state of the NVRAM mirror between partner nodes.
self
node
_links
_links
name
string
uuid
string
Data for a MetroCluster interconnect. REST: /api/cluster/metrocluster/interconnects
_links
self_link
adapter
string
Adapter
interfaces
array[interfaces]
List of objects which contain interface information such as its IP address, netmask and gateway.
mirror
mirror
multipath_policy
string
Displays the NVRAM mirror multipath policy for the nodes configured in a MetroCluster.
node
node
partner_type
string
Partner type
state
string
Adapter status
type
string
Adapter type
vlan_id
integer
VLAN ID
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
