Retrieve interconnect adapter information for nodes in MetroCluster
Retrieves interconnect adapter information for nodes in the MetroCluster, helping you review and manage the configuration of these critical connections.
HTTP method and endpoint
GET /cluster/metrocluster/interconnects
Introduced in
ONTAP 9.8
Usage notes
Retrieves a list of interconnect adapter information for nodes in the MetroCluster.
Related ONTAP Commands
metrocluster interconnect show
Learn more
interfaces.gateway |
string |
query |
False |
Filter by interfaces.gateway
interfaces.address |
string |
query |
False |
Filter by interfaces.address
interfaces.netmask |
string |
query |
False |
Filter by interfaces.netmask
partner_type |
string |
query |
False |
Filter by partner_type |
state |
string |
query |
False |
Filter by state |
vlan_id |
integer |
query |
False |
Filter by vlan_id
multipath_policy |
string |
query |
False |
Filter by multipath_policy
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
mirror.enabled |
boolean |
query |
False |
Filter by mirror.enabled
mirror.state |
string |
query |
False |
Filter by mirror.state
adapter |
string |
query |
False |
Filter by adapter |
type |
string |
query |
False |
Filter by type |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[metrocluster_interconnect] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"adapter": "string",
"interfaces": [
"address": "10.10.10.7",
"gateway": "10.1.1.1",
"netmask": "24"
"mirror": {
"state": "string"
"multipath_policy": "string",
"node": {
"name": "node1",
"partner_type": "string",
"state": "string",
"type": "string",
"vlan_id": 0
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2424994 |
MetroCluster is not supported when HAOSC is not set to "mcc", "mcc-2n" or "mccip". Run the "ha-config modify chassis" and "ha-config modify controller" commands in maintenance mode to change the HAOSC settings on node "node" in cluster "cluster". |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
2427132 |
MetroCluster is not configured on this cluster. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
interfaces
Object to setup an interface along with its default router.
address |
string |
IPv4 or IPv6 address |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length. |
mirror
enabled |
boolean |
Specifies the administrative state of the NVRAM mirror between partner nodes. |
state |
string |
Specifies the operational state of the NVRAM mirror between partner nodes. |
_links
self |
node
_links |
name |
string |
uuid |
string |
Data for a MetroCluster interconnect. REST: /api/cluster/metrocluster/interconnects
_links |
adapter |
string |
Adapter |
interfaces |
array[interfaces] |
List of objects which contain interface information such as its IP address, netmask and gateway. |
mirror |
multipath_policy |
string |
Displays the NVRAM mirror multipath policy for the nodes configured in a MetroCluster. |
node |
partner_type |
string |
Partner type |
state |
string |
Adapter status |
type |
string |
Adapter type |
vlan_id |
integer |
VLAN ID |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
