Retrieve interconnect adapter information for nodes in MetroCluster
Accesses interconnect adapter details for nodes in the MetroCluster, gaining insight into their configuration and connectivity status.
HTTP method and endpoint
GET /cluster/metrocluster/interconnects
Introduced in
ONTAP 9.8
Usage notes
Retrieves a list of interconnect adapter information for nodes in the MetroCluster.
Related ONTAP Commands
metrocluster interconnect show
Learn more
state |
string |
query |
False |
Filter by state |
vlan_id |
integer |
query |
False |
Filter by vlan_id
partner_type |
string |
query |
False |
Filter by partner_type |
interfaces.address |
string |
query |
False |
Filter by interfaces.address
interfaces.gateway |
string |
query |
False |
Filter by interfaces.gateway
interfaces.netmask |
string |
query |
False |
Filter by interfaces.netmask
adapter |
string |
query |
False |
Filter by adapter |
type |
string |
query |
False |
Filter by type |
node.name |
string |
query |
False |
Filter by node.name |
node.uuid |
string |
query |
False |
Filter by node.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[metrocluster_interconnect] |
"next": {
"href": "/api/resourcelink"
"records": [
"adapter": "string",
"interfaces": [
"address": "10.10.10.7",
"gateway": "10.1.1.1",
"netmask": "24"
"node": {
"name": "node1",
"partner_type": "string",
"state": "string",
"type": "string",
"vlan_id": 0
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
2427132 |
MetroCluster is not configured on this cluster. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
interfaces
Object to setup an interface along with its default router.
address |
string |
IPv4 or IPv6 address |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
_links
self |
node
_links |
name |
string |
uuid |
string |
Data for a MetroCluster interconnect. REST: /api/cluster/metrocluster/interconnects
_links |
adapter |
string |
Adapter |
interfaces |
array[interfaces] |
List of objects which contain interface information such as its IP address, netmask and gateway. |
node |
partner_type |
string |
Partner type |
state |
string |
Adapter status |
type |
string |
Adapter type |
vlan_id |
integer |
VLAN ID |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
