REST API reference
Retrieves configuration information for an svm in a metrocluster relationship
GET /cluster/metrocluster/svms/{cluster.uuid}/{svm.uuid}
Introduced In: 9.11
Retrieves configuration information for an SVM in a MetroCluster relationship.
cluster.uuid
string
path
True
Cluster ID
svm.uuid
string
path
True
SVM UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
cluster
cluster
configuration_state
string
Configuration state.
failed_reason
error
Reason for SVM object replication failure.
partner_svm
partner_svm
svm
svm
      "href": "/api/resourcelink"
  "cluster": {
    "name": "cluster1",
  "configuration_state": "string",
  "failed_reason": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
  "partner_svm": {
    "name": "string",
    "uuid": "string"
  "svm": {
    "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
self
cluster
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
partner_svm
name
string
MetroCluster partner SVM name.
uuid
string
MetroCluster partner SVM UUID.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
