REST API reference
Retrieve configuration information for an SVM
GET /cluster/metrocluster/svms/{cluster.uuid}/{svm.uuid}
Introduced In: 9.11
Retrieves configuration information for an SVM in a MetroCluster relationship.
cluster.uuid
string
path
True
Cluster ID
svm.uuid
string
path
True
SVM UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
cluster
cluster
configuration_state
string
Configuration state.
failed_reason
error
Reason for SVM object replication failure.
partner_svm
partner_svm
svm
svm
      "href": "/api/resourcelink"
  "cluster": {
    "name": "cluster1",
  "configuration_state": "string",
  "failed_reason": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "message": "entry doesn't exist"
  "partner_svm": {
    "name": "string",
    "uuid": "string"
  "svm": {
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
self
cluster
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
partner_svm
name
string
MetroCluster partner SVM name.
uuid
string
MetroCluster partner SVM UUID.
svm
_links
_links
name
string
uuid
string
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
