Retrieve configuration information for an SVM
Retrieves configuration information for an SVM in a MetroCluster relationship to understand and manage its settings effectively.
HTTP method and endpoint
GET /cluster/metrocluster/svms/{cluster.uuid}/{svm.uuid}
Introduced in
ONTAP 9.11
cluster.uuid |
string |
path |
True |
Cluster ID |
svm.uuid |
string |
path |
True |
SVM UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
cluster |
configuration_state |
string |
Configuration state. |
failed_reason |
Reason for SVM object replication failure. |
partner_svm |
svm |
"href": "/api/resourcelink"
"cluster": {
"name": "cluster1",
"configuration_state": "string",
"failed_reason": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"message": "entry doesn't exist"
"partner_svm": {
"name": "string",
"uuid": "string"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
_links
self |
cluster
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
partner_svm
name |
string |
MetroCluster partner SVM name. |
uuid |
string |
MetroCluster partner SVM UUID. |
svm
_links |
name |
string |
uuid |
string |
returned_error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
