Retrieve the web services configuration
Accesses the current configuration of web services, which helps you understand the existing setup and make informed adjustments if needed.
HTTP method and endpoint
GET /cluster/web
Introduced in
ONTAP 9.10
Usage notes
Retrieves the web services configuration.
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
certificate |
Certificate used by cluster and node management interfaces for TLS connection requests. |
client_enabled |
boolean |
Indicates whether client authentication is enabled. |
csrf |
enabled |
boolean |
Indicates whether remote clients can connect to the web services. |
http_enabled |
boolean |
Indicates whether HTTP is enabled. |
http_port |
integer |
HTTP port for cluster-level web services. |
https_port |
integer |
HTTPS port for cluster-level web services. |
ocsp_enabled |
boolean |
Indicates whether online certificate status protocol verification is enabled. |
per_address_limit |
integer |
The number of connections that can be processed concurrently from the same remote address. |
state |
string |
State of the cluster-level web services. |
wait_queue_capacity |
integer |
The maximum size of the wait queue for connections exceeding the per-address-limit. |
"href": "/api/resourcelink"
"certificate": {
"name": "cert1",
"csrf": {
"token": {
"concurrent_limit": 120
"per_address_limit": 42,
"state": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
certificate
_links |
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
token
concurrent_limit |
integer |
Maximum number of concurrent CSRF tokens. |
idle_timeout |
integer |
Time for which an unused CSRF token is retained, in seconds. |
max_timeout |
integer |
Time for which an unused CSRF token, regardless of usage is retained, in seconds. |
csrf
protection_enabled |
boolean |
Indicates whether CSRF protection is enabled. |
token |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
