Retrieve the web services configuration
GET /cluster/web
Introduced In: 9.10
Retrieves the web services configuration.
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
certificate  |
Certificate used by cluster and node management interfaces for TLS connection requests.  |
client_enabled  |
boolean  |
Indicates whether client authentication is enabled.  |
csrf  |
enabled  |
boolean  |
Indicates whether remote clients can connect to the web services.  |
http_enabled  |
boolean  |
Indicates whether HTTP is enabled.  |
http_port  |
integer  |
HTTP port for cluster-level web services.  |
https_port  |
integer  |
HTTPS port for cluster-level web services.  |
ocsp_enabled  |
boolean  |
Indicates whether online certificate status protocol verification is enabled.  |
per_address_limit  |
integer  |
The number of connections that can be processed concurrently from the same remote address.  |
state  |
string  |
State of the cluster-level web services.  |
wait_queue_capacity  |
integer  |
The maximum size of the wait queue for connections exceeding the per-address-limit.  |
      "href": "/api/resourcelink"
  "certificate": {
    "name": "cert1",
  "csrf": {
    "token": {
      "concurrent_limit": 120,
      "idle_timeout": 200,
      "max_timeout": 1200
  "per_address_limit": 42,
  "state": "string"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
certificate
_links  |
name  |
string  |
Certificate name  |
uuid  |
string  |
Certificate UUID  |
token
concurrent_limit  |
integer  |
Maximum number of concurrent CSRF tokens.  |
idle_timeout  |
integer  |
Time for which an unused CSRF token is retained, in seconds.  |
max_timeout  |
integer  |
Time for which an unused CSRF token, regardless of usage is retained, in seconds.  |
csrf
protection_enabled  |
boolean  |
Indicates whether CSRF protection is enabled.  |
token  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
