REST API reference
Retrieve the web services configuration
GET /cluster/web
Introduced In: 9.10
Retrieves the web services configuration.
  • system services web show
  • security ssl show
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
certificate
certificate
Certificate used by cluster and node management interfaces for TLS connection requests.
client_enabled
boolean
Indicates whether client authentication is enabled.
csrf
csrf
enabled
boolean
Indicates whether remote clients can connect to the web services.
hsts
hsts
http_enabled
boolean
Indicates whether HTTP is enabled.
http_port
integer
HTTP port for cluster-level web services.
https_port
integer
HTTPS port for cluster-level web services.
ocsp_enabled
boolean
Indicates whether online certificate status protocol verification is enabled.
per_address_limit
integer
The number of connections that can be processed concurrently from the same remote address.
state
string
State of the cluster-level web services.
wait_queue_capacity
integer
The maximum size of the wait queue for connections exceeding the per-address-limit.
      "href": "/api/resourcelink"
  "certificate": {
    "name": "cert1",
  "csrf": {
    "token": {
      "concurrent_limit": 120,
      "idle_timeout": 200,
      "max_timeout": 1200
  "hsts": {
    "max_age": 31536000
  "per_address_limit": 42,
  "state": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
certificate
_links
_links
name
string
Certificate name
uuid
string
Certificate UUID
token
concurrent_limit
integer
Maximum number of concurrent CSRF tokens.
idle_timeout
integer
Time for which an unused CSRF token is retained, in seconds.
max_timeout
integer
Time for which an unused CSRF token, regardless of usage is retained, in seconds.
csrf
protection_enabled
boolean
Indicates whether CSRF protection is enabled.
token
token
hsts
enabled
boolean
Indicates whether HTTP Strict Transport Security (HSTS) is enabled.
max_age
integer
HTTPS Strict Transport Security (HSTS) max-age value in seconds. The maximum time, in seconds, that the browser should remember that a site is only to be accessed using HTTPS.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
