REST API reference
Retrieve Ethernet switches attached to a chassis
Retrieves information about Ethernet switches connected to a chassis, which helps you manage and troubleshoot network configurations.
HTTP method and endpoint
GET /network/ethernet/switches
Introduced in
ONTAP 9.8
Usage notes
Retrieves the ethernet switches attached to the chassis.
  • system switch ethernet show
network
string
query
False
Filter by network
address
string
query
False
Filter by address
model
string
query
False
Filter by model
monitoring.enabled
boolean
query
False
Filter by monitoring.enabled
monitoring.reason
string
query
False
Filter by monitoring.reason
monitoring.monitored
boolean
query
False
Filter by monitoring.monitored
serial_number
string
query
False
Filter by serial_number
name
string
query
False
Filter by name
version
string
query
False
Filter by version
discovered
boolean
query
False
Filter by discovered
snmp.version
string
query
False
Filter by snmp.version
snmp.user
string
query
False
Filter by snmp.user
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[switch]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "address": "string",
      "model": "string",
      "monitoring": {
        "reason": "string"
      "name": "string",
      "network": "string",
      "serial_number": "string",
      "snmp": {
        "user": "string",
        "version": "string"
      "version": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
monitoring
enabled
boolean
Enable Health Monitoring.
monitored
boolean
Is Monitored.
reason
string
Reason For Not Monitoring.
snmp
user
string
Community String or SNMPv3 Username.
version
string
SNMP Version.
switch
Ethernet Switch REST API
_links
self_link
address
string
IP Address.
discovered
boolean
Discovered By ONTAP CDP/LLDP
  • readOnly: 1
  • Introduced in: 9.8
model
string
Model Number.
monitoring
monitoring
name
string
Name.
network
string
Switch Network.
serial_number
string
Serial Number.
snmp
snmp
version
string
Software Version.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
