Retrieve Ethernet switches attached to a chassis
Retrieves Ethernet switches connected to a chassis to monitor and manage network configurations and connections effectively.
HTTP method and endpoint
GET /network/ethernet/switches
Introduced in
ONTAP 9.8
Usage notes
Retrieves the ethernet switches attached to the chassis.
Related ONTAP commands
system switch ethernet show
Learn more
version |
string |
query |
False |
Filter by version |
model |
string |
query |
False |
Filter by model |
monitoring.reason |
string |
query |
False |
Filter by monitoring.reason |
monitoring.monitored |
boolean |
query |
False |
Filter by monitoring.monitored |
monitoring.enabled |
boolean |
query |
False |
Filter by monitoring.enabled |
address |
string |
query |
False |
Filter by address |
serial_number |
string |
query |
False |
Filter by serial_number |
network |
string |
query |
False |
Filter by network |
discovered |
boolean |
query |
False |
Filter by discovered |
name |
string |
query |
False |
Filter by name |
snmp.user |
string |
query |
False |
Filter by snmp.user |
snmp.version |
string |
query |
False |
Filter by snmp.version |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[switch] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"address": "string",
"model": "string",
"monitoring": {
"reason": "string"
"name": "string",
"network": "string",
"serial_number": "string",
"snmp": {
"user": "string",
"version": "string"
"version": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
monitoring
enabled |
boolean |
Enable Health Monitoring. |
monitored |
boolean |
Is Monitored. |
reason |
string |
Reason For Not Monitoring. |
snmp
user |
string |
Community String or SNMPv3 Username. |
version |
string |
SNMP Version. |
switch
Ethernet Switch REST API
_links |
address |
string |
IP Address. |
discovered |
boolean |
Discovered By ONTAP CDP/LLDP
model |
string |
Model Number. |
monitoring |
name |
string |
Name. |
network |
string |
Switch Network. |
serial_number |
string |
Serial Number. |
snmp |
version |
string |
Software Version. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
