REST API reference
Retrieve Ethernet switches attached to a chassis
Accesses information on Ethernet switches connected to a chassis. Use this endpoint to view details about the network configuration and connectivity of attached switches.
HTTP method and endpoint
GET /network/ethernet/switches
Introduced in
ONTAP 9.8
Usage notes
Retrieves a collection of Ethernet switches.
  • system switch ethernet show
discovered
boolean
query
False
Filter by discovered
monitoring.reason
string
query
False
Filter by monitoring.reason
monitoring.enabled
boolean
query
False
Filter by monitoring.enabled
monitoring.monitored
boolean
query
False
Filter by monitoring.monitored
address
string
query
False
Filter by address
serial_number
string
query
False
Filter by serial_number
snmp.version
string
query
False
Filter by snmp.version
snmp.user
string
query
False
Filter by snmp.user
version
string
query
False
Filter by version
rcf_version
string
query
False
Filter by rcf_version
  • Introduced in: 9.17
role
string
query
False
Filter by role
name
string
query
False
Filter by name
model
string
query
False
Filter by model
network
string
query
False
Filter by network
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[switch]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "address": "string",
      "model": "string",
      "monitoring": {
        "reason": "string"
      "name": "string",
      "network": "string",
      "rcf_version": "RCF NX9336C-FX2 v1.13 1-CLUSTER",
      "role": [
        "cluster+storage"
      "serial_number": "string",
      "snmp": {
        "user": "string",
        "version": "string"
      "version": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
monitoring
enabled
boolean
Enable Health Monitoring.
monitored
boolean
Is Monitored.
reason
string
Reason For Not Monitoring.
snmp
user
string
Community String or SNMPv3 Username.
version
string
SNMP Version.
switch
Ethernet Switch REST API
_links
self_link
address
string
IP Address.
discovered
boolean
Discovered By ONTAP CDP/LLDP
  • readOnly: 1
  • Introduced in: 9.8
  • x-nullable: true
model
string
Model Number.
monitoring
monitoring
name
string
Name.
network
string
Switch Network.
rcf_version
string
The switch reference configuration file (RCF) version.
role
string
Switch role based on the interface configurations. Using '+' to combine multiple roles. Available role types are: cluster, multicluster, storage, multistorage, metrocluster.
serial_number
string
Serial Number.
snmp
snmp
version
string
Software Version.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
