REST API reference
Retrieve Ethernet switches attached to a chassis
GET /network/ethernet/switches
Introduced In: 9.8
Retrieves a collection of Ethernet switches.
  • system switch ethernet show
monitoring.enabled
boolean
query
False
Filter by monitoring.enabled
monitoring.monitored
boolean
query
False
Filter by monitoring.monitored
monitoring.reason
string
query
False
Filter by monitoring.reason
snmp.version
string
query
False
Filter by snmp.version
snmp.user
string
query
False
Filter by snmp.user
role
string
query
False
Filter by role
  • Introduced in: 9.17
serial_number
string
query
False
Filter by serial_number
model
string
query
False
Filter by model
address
string
query
False
Filter by address
name
string
query
False
Filter by name
discovered
boolean
query
False
Filter by discovered
network
string
query
False
Filter by network
rcf_version
string
query
False
Filter by rcf_version
version
string
query
False
Filter by version
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[switch]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "address": "string",
      "model": "string",
      "monitoring": {
        "reason": "string"
      "name": "string",
      "network": "string",
      "rcf_version": "RCF NX9336C-FX2 v1.13 1-CLUSTER",
      "role": [
        "cluster+storage"
      "serial_number": "string",
      "snmp": {
        "user": "string",
        "version": "string"
      "version": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
monitoring
enabled
boolean
Enable Health Monitoring.
monitored
boolean
Is Monitored.
reason
string
Reason For Not Monitoring.
snmp
user
string
Community String or SNMPv3 Username.
version
string
SNMP Version.
switch
Ethernet Switch REST API
_links
self_link
address
string
IP Address.
discovered
boolean
Discovered By ONTAP CDP/LLDP
  • readOnly: 1
  • Introduced in: 9.8
  • x-nullable: true
model
string
Model Number.
monitoring
monitoring
name
string
Name.
network
string
Switch Network.
rcf_version
string
The switch reference configuration file (RCF) version.
role
string
Switch role based on the interface configurations. Using '+' to combine multiple roles. Available role types are: cluster, multicluster, storage, multistorage, metrocluster.
serial_number
string
Serial Number.
snmp
snmp
version
string
Software Version.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
