REST API reference
Retrieve details for all subnets
Retrieves details for all subnets to gain insight into your network configuration and manage subnet resources effectively.
HTTP method and endpoint
GET /network/ip/subnets
Introduced in
ONTAP 9.11
  • network subnet show
broadcast_domain.uuid
string
query
False
Filter by broadcast_domain.uuid
broadcast_domain.name
string
query
False
Filter by broadcast_domain.name
subnet.netmask
string
query
False
Filter by subnet.netmask
subnet.family
string
query
False
Filter by subnet.family
subnet.address
string
query
False
Filter by subnet.address
used_count
integer
query
False
Filter by used_count
available_ip_ranges.start
string
query
False
Filter by available_ip_ranges.start
available_ip_ranges.family
string
query
False
Filter by available_ip_ranges.family
available_ip_ranges.end
string
query
False
Filter by available_ip_ranges.end
gateway
string
query
False
Filter by gateway
uuid
string
query
False
Filter by uuid
ip_ranges.start
string
query
False
Filter by ip_ranges.start
ip_ranges.family
string
query
False
Filter by ip_ranges.family
ip_ranges.end
string
query
False
Filter by ip_ranges.end
name
string
query
False
Filter by name
ipspace.name
string
query
False
Filter by ipspace.name
ipspace.uuid
string
query
False
Filter by ipspace.uuid
total_count
integer
query
False
Filter by total_count
available_count
integer
query
False
Filter by available_count
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
records
array[ip_subnet]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "available_count": 0,
      "available_ip_ranges": [
          "end": "10.10.10.7",
          "family": "string",
          "start": "10.10.10.7"
      "broadcast_domain": {
        "name": "bd1",
      "fail_if_lifs_conflict": null,
      "gateway": "10.1.1.1",
      "ip_ranges": [
          "family": "string",
      "ipspace": {
        "name": "exchange",
      "name": "subnet1",
      "subnet": {
        "address": "10.10.10.7",
        "family": "string",
        "netmask": "24"
      "total_count": 0,
      "used_count": 0,
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ip_address_range
IP address range
end
string
IPv4 or IPv6 address
family
string
IPv4 or IPv6
start
string
broadcast_domain
The broadcast domain that the subnet is associated with. Either the UUID or name must be supplied on POST.
_links
_links
name
string
Name of the broadcast domain, scoped to its IPspace
uuid
string
Broadcast domain UUID
ipspace
The IPspace that the subnet is associated with. Either the UUID or name must be supplied on POST.
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
ip_info
IP information
address
string
family
string
IPv4 or IPv6
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
ip_subnet
_links
_links
available_count
integer
available_ip_ranges
array[ip_address_range]
broadcast_domain
broadcast_domain
gateway
string
The IP address of the gateway for this subnet.
ip_ranges
ipspace
ipspace
name
string
Subnet name
subnet
ip_info
IP information
total_count
integer
used_count
integer
uuid
string
The UUID that uniquely identifies the subnet.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
