Retrieve details for all subnets
GET /network/ip/subnets
Introduced In: 9.11
Retrieves details for all subnets.
Related ONTAP Commands
network subnet show
name |
string |
query |
False |
Filter by name |
gateway |
string |
query |
False |
Filter by gateway |
subnet.netmask |
string |
query |
False |
Filter by subnet.netmask |
subnet.address |
string |
query |
False |
Filter by subnet.address |
subnet.family |
string |
query |
False |
Filter by subnet.family |
ipspace.name |
string |
query |
False |
Filter by ipspace.name |
ipspace.uuid |
string |
query |
False |
Filter by ipspace.uuid |
used_count |
integer |
query |
False |
Filter by used_count |
ip_ranges.end |
string |
query |
False |
Filter by ip_ranges.end |
ip_ranges.family |
string |
query |
False |
Filter by ip_ranges.family |
ip_ranges.start |
string |
query |
False |
Filter by ip_ranges.start |
available_ip_ranges.end |
string |
query |
False |
Filter by available_ip_ranges.end |
available_ip_ranges.family |
string |
query |
False |
Filter by available_ip_ranges.family |
available_ip_ranges.start |
string |
query |
False |
Filter by available_ip_ranges.start |
uuid |
string |
query |
False |
Filter by uuid |
broadcast_domain.uuid |
string |
query |
False |
Filter by broadcast_domain.uuid |
broadcast_domain.name |
string |
query |
False |
Filter by broadcast_domain.name |
available_count |
integer |
query |
False |
Filter by available_count |
total_count |
integer |
query |
False |
Filter by total_count |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[ip_subnet] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"available_count": 0,
"available_ip_ranges": [
"end": "10.10.10.7",
"family": "string",
"start": "10.10.10.7"
"broadcast_domain": {
"name": "bd1",
"fail_if_lifs_conflict": true,
"gateway": "10.1.1.1",
"ip_ranges": [
"family": "string",
"ipspace": {
"name": "Default",
"name": "subnet1",
"subnet": {
"address": "10.10.10.7",
"family": "string",
"netmask": "24"
"total_count": 0,
"used_count": 0,
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ip_address_range
IP address range
end |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
start |
string |
broadcast_domain
The broadcast domain that the subnet is associated with. Either the UUID or name must be supplied on POST.
_links |
name |
string |
Name of the broadcast domain, scoped to its IPspace |
uuid |
string |
Broadcast domain UUID |
ipspace
The IPspace that the subnet is associated with. Either the UUID or name must be supplied on POST.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
ip_info
IP information
address |
string |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length. |
ip_subnet
_links |
available_count |
integer |
available_ip_ranges |
array[ip_address_range] |
broadcast_domain |
The broadcast domain that the subnet is associated with. Either the UUID or name must be supplied on POST. |
gateway |
string |
The IP address of the gateway for this subnet. |
ip_ranges |
ipspace |
The IPspace that the subnet is associated with. Either the UUID or name must be supplied on POST. |
name |
string |
Subnet name |
subnet |
IP information |
total_count |
integer |
used_count |
integer |
uuid |
string |
The UUID that uniquely identifies the subnet. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
