Retrieve details for all subnets
Retrieves detailed information about all subnets, which is useful for managing network configurations and understanding the layout of your network resources.
HTTP method and endpoint
GET /network/ip/subnets
Introduced in
ONTAP 9.11
Usage notes
Retrieves details for all subnets.
Related ONTAP Commands
network subnet show
ipspace.uuid |
string |
query |
False |
Filter by ipspace.uuid |
ipspace.name |
string |
query |
False |
Filter by ipspace.name |
name |
string |
query |
False |
Filter by name |
gateway |
string |
query |
False |
Filter by gateway |
uuid |
string |
query |
False |
Filter by uuid |
subnet.family |
string |
query |
False |
Filter by subnet.family |
subnet.netmask |
string |
query |
False |
Filter by subnet.netmask |
subnet.address |
string |
query |
False |
Filter by subnet.address |
total_count |
integer |
query |
False |
Filter by total_count |
used_count |
integer |
query |
False |
Filter by used_count |
available_ip_ranges.end |
string |
query |
False |
Filter by available_ip_ranges.end |
available_ip_ranges.start |
string |
query |
False |
Filter by available_ip_ranges.start |
available_ip_ranges.family |
string |
query |
False |
Filter by available_ip_ranges.family |
ip_ranges.end |
string |
query |
False |
Filter by ip_ranges.end |
ip_ranges.start |
string |
query |
False |
Filter by ip_ranges.start |
ip_ranges.family |
string |
query |
False |
Filter by ip_ranges.family |
available_count |
integer |
query |
False |
Filter by available_count |
broadcast_domain.name |
string |
query |
False |
Filter by broadcast_domain.name |
broadcast_domain.uuid |
string |
query |
False |
Filter by broadcast_domain.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[ip_subnet] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"available_count": 0,
"available_ip_ranges": [
"end": "10.10.10.7",
"family": "string",
"start": "10.10.10.7"
"broadcast_domain": {
"name": "bd1",
"fail_if_lifs_conflict": true,
"gateway": "10.1.1.1",
"ip_ranges": [
"family": "string",
"ipspace": {
"name": "Default",
"name": "subnet1",
"subnet": {
"address": "10.10.10.7",
"family": "string",
"netmask": "24"
"total_count": 0,
"used_count": 0,
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ip_address_range
IP address range
end |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
start |
string |
broadcast_domain
The broadcast domain that the subnet is associated with. Either the UUID or name must be supplied on POST.
_links |
name |
string |
Name of the broadcast domain, scoped to its IPspace |
uuid |
string |
Broadcast domain UUID |
ipspace
The IPspace that the subnet is associated with. Either the UUID or name must be supplied on POST.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
ip_info
IP information
address |
string |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length. |
ip_subnet
_links |
available_count |
integer |
available_ip_ranges |
array[ip_address_range] |
broadcast_domain |
The broadcast domain that the subnet is associated with. Either the UUID or name must be supplied on POST. |
gateway |
string |
The IP address of the gateway for this subnet. |
ip_ranges |
ipspace |
The IPspace that the subnet is associated with. Either the UUID or name must be supplied on POST. |
name |
string |
Subnet name |
subnet |
IP information |
total_count |
integer |
used_count |
integer |
uuid |
string |
The UUID that uniquely identifies the subnet. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
