Retrieve S3 audit configurations
Retrieves the S3 audit configurations to examine the current auditing settings for S3 operations. This can be useful for monitoring and compliance purposes within your storage environment.
HTTP method and endpoint
GET /protocols/audit/{svm.uuid}/object-store
Introduced in
ONTAP 9.10
Related ONTAP commands
vserver object-store-server audit show
Learn more
events.management |
boolean |
query |
False |
Filter by events.management |
events.data |
boolean |
query |
False |
Filter by events.data |
svm.name |
string |
query |
False |
Filter by svm.name |
log.retention.duration |
string |
query |
False |
Filter by log.retention.duration |
log.retention.count |
integer |
query |
False |
Filter by log.retention.count |
log.rotation.schedule.months |
integer |
query |
False |
Filter by log.rotation.schedule.months
log.rotation.schedule.minutes |
integer |
query |
False |
Filter by log.rotation.schedule.minutes
log.rotation.schedule.days |
integer |
query |
False |
Filter by log.rotation.schedule.days
log.rotation.schedule.weekdays |
integer |
query |
False |
Filter by log.rotation.schedule.weekdays
log.rotation.schedule.hours |
integer |
query |
False |
Filter by log.rotation.schedule.hours
log.rotation.size |
integer |
query |
False |
Filter by log.rotation.size |
log.format |
string |
query |
False |
Filter by log.format |
enabled |
boolean |
query |
False |
Filter by enabled |
log_path |
string |
query |
False |
Filter by log_path |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
enabled |
boolean |
Specifies whether or not auditing is enabled on the SVM. |
events |
log |
log_path |
string |
The audit log destination path where consolidated audit logs are stored. |
svm |
"log": {
"href": "/api/resourcelink"
"format": "string",
"retention": {
"duration": "P4DT12H30M5S"
"rotation": {
"schedule": {
"days": [
"integer"
"hours": [
"integer"
"minutes": [
"integer"
"months": [
"integer"
"weekdays": [
"integer"
"log_path": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
events
data |
boolean |
Data events |
management |
boolean |
Management events |
href |
string |
_links
self |
retention
count |
integer |
Determines how many audit log files to retain before rotating the oldest log file out. This is mutually exclusive with "duration". |
duration |
string |
Specifies an ISO-8601 format date and time to retain the audit log file. The audit log files are deleted once they reach the specified date/time. This is mutually exclusive with "count". |
audit_schedule
Rotates the audit logs based on a schedule by using the time-based rotation parameters in any combination. The rotation schedule is calculated by using all the time-related values.
days |
array[integer] |
Specifies the day of the month schedule to rotate audit log. Leave empty for all. |
hours |
array[integer] |
Specifies the hourly schedule to rotate audit log. Leave empty for all. |
minutes |
array[integer] |
Specifies the minutes schedule to rotate the audit log. |
months |
array[integer] |
Specifies the months schedule to rotate audit log. Leave empty for all. |
weekdays |
array[integer] |
Specifies the weekdays schedule to rotate audit log. Leave empty for all. |
rotation
Audit event log files are rotated when they reach a configured threshold log size or are on a configured schedule. When an event log file is rotated, the scheduled consolidation task first renames the active converted file to a time-stamped archive file, and then creates a new active converted event log file.
now |
boolean |
Manually rotates the audit logs. Optional in PATCH only. Not available in POST. |
schedule |
Rotates the audit logs based on a schedule by using the time-based rotation parameters in any combination. The rotation schedule is calculated by using all the time-related values. |
size |
integer |
Rotates logs based on log size in bytes. |
s3_log
_links |
format |
string |
Format in which the logs are generated by the consolidation process. Possible values are:
retention |
rotation |
Audit event log files are rotated when they reach a configured threshold log size or are on a configured schedule. When an event log file is rotated, the scheduled consolidation task first renames the active converted file to a time-stamped archive file, and then creates a new active converted event log file. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
