REST API reference
Retrieve an S3 audit configurations
Accesses S3 audit configurations to review or manage audit settings related to object storage operations within ONTAP.
HTTP method and endpoint
GET /protocols/audit/{svm.uuid}/object-store
Introduced in
ONTAP 9.10
Usage notes
Retrieves S3 audit configurations.
  • vserver object-store-server audit show
log_path
string
query
False
Filter by log_path
svm.name
string
query
False
Filter by svm.name
events.data
boolean
query
False
Filter by events.data
events.management
boolean
query
False
Filter by events.management
log.rotation.size
integer
query
False
Filter by log.rotation.size
log.rotation.schedule.days
integer
query
False
Filter by log.rotation.schedule.days
  • Max value: 31
  • Min value: 1
log.rotation.schedule.hours
integer
query
False
Filter by log.rotation.schedule.hours
  • Max value: 23
  • Min value: 0
log.rotation.schedule.weekdays
integer
query
False
Filter by log.rotation.schedule.weekdays
  • Max value: 6
  • Min value: 0
log.rotation.schedule.minutes
integer
query
False
Filter by log.rotation.schedule.minutes
  • Max value: 59
  • Min value: 0
log.rotation.schedule.months
integer
query
False
Filter by log.rotation.schedule.months
  • Max value: 12
  • Min value: 1
log.format
string
query
False
Filter by log.format
log.retention.duration
string
query
False
Filter by log.retention.duration
log.retention.count
integer
query
False
Filter by log.retention.count
enabled
boolean
query
False
Filter by enabled
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
enabled
boolean
Specifies whether or not auditing is enabled on the SVM.
events
events
log
s3_log
log_path
string
The audit log destination path where consolidated audit logs are stored.
svm
svm
  "log": {
        "href": "/api/resourcelink"
    "format": "string",
    "retention": {
      "duration": "P4DT12H30M5S"
    "rotation": {
      "schedule": {
        "days": [
          "integer"
        "hours": [
          "integer"
        "minutes": [
          "integer"
        "months": [
          "integer"
        "weekdays": [
          "integer"
  "log_path": "string",
  "svm": {
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
events
data
boolean
Data events
management
boolean
Management events
string
self
retention
count
integer
Determines how many audit log files to retain before rotating the oldest log file out. This is mutually exclusive with "duration".
duration
string
Specifies an ISO-8601 format date and time to retain the audit log file. The audit log files are deleted once they reach the specified date/time. This is mutually exclusive with "count".
audit_schedule
Rotates the audit logs based on a schedule by using the time-based rotation parameters in any combination. The rotation schedule is calculated by using all the time-related values.
days
array[integer]
Specifies the day of the month schedule to rotate audit log. Leave empty for all.
hours
array[integer]
Specifies the hourly schedule to rotate audit log. Leave empty for all.
minutes
array[integer]
Specifies the minutes schedule to rotate the audit log.
months
array[integer]
Specifies the months schedule to rotate audit log. Leave empty for all.
weekdays
array[integer]
Specifies the weekdays schedule to rotate audit log. Leave empty for all.
rotation
Audit event log files are rotated when they reach a configured threshold log size or are on a configured schedule. When an event log file is rotated, the scheduled consolidation task first renames the active converted file to a time-stamped archive file, and then creates a new active converted event log file.
now
boolean
Manually rotates the audit logs. Optional in PATCH only. Not available in POST.
schedule
audit_schedule
size
integer
Rotates logs based on log size in bytes.
s3_log
_links
_links
format
string
Format in which the logs are generated by the consolidation process. Possible values are:
  • json - ONTAP-specific Json log format.
    • Default value: 1
    • enum: ["json"]
    • Introduced in: 9.10
    • x-nullable: true
retention
retention
rotation
rotation
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
