Retrieve an S3 audit configurations
GET /protocols/audit/{svm.uuid}/object-store
Introduced In: 9.10
Retrieves S3 audit configurations.
Related ONTAP commands
vserver object-store-server audit show
Learn more
events.management |
boolean |
query |
False |
Filter by events.management |
events.data |
boolean |
query |
False |
Filter by events.data |
log_path |
string |
query |
False |
Filter by log_path |
log.rotation.size |
integer |
query |
False |
Filter by log.rotation.size |
log.rotation.schedule.hours |
integer |
query |
False |
Filter by log.rotation.schedule.hours
log.rotation.schedule.days |
integer |
query |
False |
Filter by log.rotation.schedule.days
log.rotation.schedule.weekdays |
integer |
query |
False |
Filter by log.rotation.schedule.weekdays
log.rotation.schedule.minutes |
integer |
query |
False |
Filter by log.rotation.schedule.minutes
log.rotation.schedule.months |
integer |
query |
False |
Filter by log.rotation.schedule.months
log.format |
string |
query |
False |
Filter by log.format |
log.retention.count |
integer |
query |
False |
Filter by log.retention.count |
log.retention.duration |
string |
query |
False |
Filter by log.retention.duration |
enabled |
boolean |
query |
False |
Filter by enabled |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
enabled |
boolean |
Specifies whether or not auditing is enabled on the SVM. |
events |
log |
log_path |
string |
The audit log destination path where consolidated audit logs are stored. |
svm |
"log": {
"href": "/api/resourcelink"
"format": "string",
"retention": {
"duration": "P4DT12H30M5S"
"rotation": {
"schedule": {
"days": [
"integer"
"hours": [
"integer"
"minutes": [
"integer"
"months": [
"integer"
"weekdays": [
"integer"
"log_path": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
events
data |
boolean |
Data events |
management |
boolean |
Management events |
href |
string |
_links
self |
retention
count |
integer |
Determines how many audit log files to retain before rotating the oldest log file out. This is mutually exclusive with "duration". |
duration |
string |
Specifies an ISO-8601 format date and time to retain the audit log file. The audit log files are deleted once they reach the specified date/time. This is mutually exclusive with "count". |
audit_schedule
Rotates the audit logs based on a schedule by using the time-based rotation parameters in any combination. The rotation schedule is calculated by using all the time-related values.
days |
array[integer] |
Specifies the day of the month schedule to rotate audit log. Leave empty for all. |
hours |
array[integer] |
Specifies the hourly schedule to rotate audit log. Leave empty for all. |
minutes |
array[integer] |
Specifies the minutes schedule to rotate the audit log. |
months |
array[integer] |
Specifies the months schedule to rotate audit log. Leave empty for all. |
weekdays |
array[integer] |
Specifies the weekdays schedule to rotate audit log. Leave empty for all. |
rotation
Audit event log files are rotated when they reach a configured threshold log size or are on a configured schedule. When an event log file is rotated, the scheduled consolidation task first renames the active converted file to a time-stamped archive file, and then creates a new active converted event log file.
now |
boolean |
Manually rotates the audit logs. Optional in PATCH only. Not available in POST. |
schedule |
Rotates the audit logs based on a schedule by using the time-based rotation parameters in any combination. The rotation schedule is calculated by using all the time-related values. |
size |
integer |
Rotates logs based on log size in bytes. |
s3_log
_links |
format |
string |
Format in which the logs are generated by the consolidation process. Possible values are:
retention |
rotation |
Audit event log files are rotated when they reach a configured threshold log size or are on a configured schedule. When an event log file is rotated, the scheduled consolidation task first renames the active converted file to a time-stamped archive file, and then creates a new active converted event log file. |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
