Retrieve privileges for all local, or Active Directory users or groups and SVMs
Retrieves the privileges assigned to a specified local or Active Directory user, group, or Storage Virtual Machine (SVM). Use this endpoint to manage and verify access rights within your networked storage environment.
HTTP method and endpoint
GET /protocols/cifs/users-and-groups/privileges
Introduced in
ONTAP 9.9
Usage notes
Retrieves privileges of the specified local or Active Directory user or group and SVM.
Related ONTAP commands
vserver cifs users-and-groups privilege show
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
name |
string |
query |
False |
Filter by name |
privileges |
string |
query |
False |
Filter by privileges |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of local or Active Directory user or group records. |
records |
array[user_group_privileges] |
"next": {
"href": "/api/resourcelink"
"records": [
"name": "user1",
"privileges": [
"string"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
_links |
name |
string |
Local or Active Directory user or group name. |
privileges |
array[string] |
An array of privileges associated with the local or Active Directory user or group. The available values are:
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
