REST API reference
Retrieve privileges for all local, or Active Directory users or groups and SVMs
Accesses privileges for specified local or Active Directory users or groups and SVMs. Use this to review and manage user or group permissions effectively within your storage environment.
HTTP method and endpoint
GET /protocols/cifs/users-and-groups/privileges
Introduced in
ONTAP 9.9
Usage notes
Retrieves privileges of the specified local or Active Directory user or group and SVM.
  • vserver cifs users-and-groups privilege show
name
string
query
False
Filter by name
privileges
string
query
False
Filter by privileges
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of local or Active Directory user or group records.
records
array[user_group_privileges]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "name": "user1",
      "privileges": [
        "string"
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
_links
_links
name
string
Local or Active Directory user or group name.
privileges
array[string]
An array of privileges associated with the local or Active Directory user or group. The available values are:
  • SeTcbPrivilege - Allows user to act as part of the operating system
  • SeBackupPrivilege - Allows user to back up files and directories, overriding any ACLs
  • SeRestorePrivilege - Allows user to restore files and directories, overriding any ACLs
  • SeTakeOwnershipPrivilege - Allows user to take ownership of files or other objects
  • SeSecurityPrivilege - Allows user to manage auditing and viewing/dumping/clearing the security log
  • SeChangeNotifyPrivilege - Allows user to bypass traverse checking
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
