Retrieve privileges for all local, or Active Directory users or groups and SVMs
GET /protocols/cifs/users-and-groups/privileges
Introduced In: 9.10
Retrieves privileges of the specified local or Active Directory user or group and SVM.
Related ONTAP commands
vserver cifs users-and-groups privilege show
privileges |
string |
query |
False |
Filter by privileges |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
name |
string |
query |
False |
Filter by name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of local or Active Directory user or group records. |
records |
array[user_group_privileges] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"name": "user1",
"privileges": [
"string"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
uuid |
string |
_links |
name |
string |
Local or Active Directory user or group name. |
privileges |
array[string] |
An array of privileges associated with the local or Active Directory user or group. The available values are:
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
