REST API reference
Retrieve NVMe subsystem hosts
Retrieves NVMe subsystem hosts to examine the host configurations associated with an NVMe subsystem. This is useful for understanding the network paths and connections available for NVMe operations.
HTTP method and endpoint
GET /protocols/nvme/subsystems/{subsystem.uuid}/hosts
Introduced in
ONTAP 9.6
Usage notes
Retrieves the NVMe subsystem hosts of an NVMe subsystem.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • subsystem_maps.*
  • vserver nvme subsystem map show
  • vserver nvme subsystem show
subsystem.uuid
string
path
True
The unique identifier of the NVMe subsystem.
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[nvme_subsystem_host]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "io_queue": {
        "count": 4,
        "depth": 32
      "nqn": "nqn.1992-01.example.com:string",
      "subsystem": {
Status: Default
ONTAP Error Response Codes
Error Code Description
72090001
The NVMe subsystem does not exist.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
io_queue
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller.
count
integer
The number of I/O queue pairs. The default value is inherited from the owning NVMe subsystem.
depth
integer
The I/O queue depth. The default value is inherited from the owning NVMe subsystem.
subsystem
The NVMe subsystem to which the NVMe host has been provisioned.
_links
_links
uuid
string
records
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
_links
_links
io_queue
io_queue
nqn
string
The NVMe qualified name (NQN) used to identify the NVMe storage target. Not allowed in POST when the records property is used.
subsystem
subsystem
nvme_subsystem_host
_links
_links
io_queue
io_queue
nqn
string
subsystem
subsystem
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
