Retrieve NVMe subsystem hosts
Retrieves the NVMe subsystem hosts to view the hosts associated with a specific NVMe subsystem. This helps you understand the host connections in your storage environment.
HTTP method and endpoint
GET /protocols/nvme/subsystems/{subsystem.uuid}/hosts
Introduced in
ONTAP 9.6
Usage notes
Retrieves the NVMe subsystem hosts of an NVMe subsystem.
Related ONTAP commands
vserver nvme subsystem map show -
vserver nvme subsystem show
Learn more
subsystem.uuid |
string |
path |
True |
The unique identifier of the NVMe subsystem. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[nvme_subsystem_host] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"dh_hmac_chap": {
"group_size": "string",
"hash_function": "string",
"mode": "bidirectional"
"io_queue": {
"count": 4,
"depth": 32
"nqn": "nqn.1992-01.example.com:string",
"priority": "string",
"proximity": {
"peer_svms": [
"name": "peer1",
"uuid": "4204cf77-4c82-9bdb-5644-b5a841c097a9"
"subsystem": {
"name": "subsystem1",
"tls": {
"key_type": "configured"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
72090001 |
The NVMe subsystem does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
dh_hmac_chap
A container for the configuration of NVMe in-band authentication using the DH-HMAC-CHAP protocol for a host.
group_size |
string |
The Diffie-Hellman group size for NVMe in-band authentication. When property |
hash_function |
string |
The hash function for NVMe in-band authentication. When property |
mode |
string |
The expected NVMe in-band authentication mode for the host. This property is an indication of which secrets are configured for the host. When set to:
io_queue
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller.
count |
integer |
The number of I/O queue pairs. Absence of this property in GET implies property priority is set and platform and transport protocol specific values for I/O queue count is being used. Valid in GET only. |
depth |
integer |
The I/O queue depth. Absence of this property in GET implies property priority is set and platform and transport protocol specific values for I/O queue depth is being used. Valid in GET only. |
peer_svms
A reference to an SVM peer relationship.
_links |
name |
string |
The local name of the peer SVM. This name is unique among all local and peer SVMs. |
uuid |
string |
The unique identifier of the SVM peer relationship. This is the UUID of the relationship, not the UUID of the peer SVM itself. |
proximity
Properties that define the SVMs to which the host is proximal. This information is used to properly report active optimized and active non-optimized network paths using an NVMe controller. If no configuration has been specified for the host, the sub-object is not present in GET requests.
These properties apply to all instances of the host in the NVMe subsystem in the SVM and its peers.
local_svm |
boolean |
A boolean that indicates if the host is proximal to the SVM for which it is configured. |
peer_svms |
array[peer_svms] |
An array of remote peer SVMs to which the host is proximal. |
io_queue
count |
integer |
The number of I/O queue pairs. The default value is inherited from the owning NVMe subsystem. |
depth |
integer |
The I/O queue depth. The default value is inherited from the owning NVMe subsystem. |
subsystem
The NVMe subsystem to which the NVMe host has been provisioned.
_links |
name |
string |
The name of the NVMe subsystem. |
uuid |
string |
tls
A container for the configuration for NVMe/TCP-TLS transport session for the host.
key_type |
string |
The method by which the TLS pre-shared key (PSK) is configured for the host. Optional in POST. The values for property Possible values:
This property defaults to |
records
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
_links |
dh_hmac_chap |
A container for the configuration of NVMe in-band authentication using the DH-HMAC-CHAP protocol for a host. |
io_queue |
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller. |
nqn |
string |
The NVMe qualified name (NQN) used to identify the NVMe storage target. Not allowed in POST when the |
subsystem |
The NVMe subsystem to which the NVMe host has been provisioned. |
tls |
A container for the configuration for NVMe/TCP-TLS transport session for the host. |
nvme_subsystem_host
_links |
dh_hmac_chap |
io_queue |
nqn |
string |
The NVMe qualified name (NQN) used to identify the NVMe storage target. |
priority |
string |
The host priority setting allocates appropriate NVMe I/O queues (count and depth) for the host to submit I/O commands. Absence of this property in GET implies io_queue count and I/O queue depth are being used. |
proximity |
Properties that define the SVMs to which the host is proximal. This information is used to properly report active optimized and active non-optimized network paths using an NVMe controller. If no configuration has been specified for the host, the sub-object is not present in GET requests. These properties apply to all instances of the host in the NVMe subsystem in the SVM and its peers. |
subsystem |
tls |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
