Retrieve NVMe subsystem hosts
Retrieves NVMe subsystem hosts to view the associated hosts for a specific NVMe subsystem. This is useful when you need to examine host configurations or troubleshoot NVMe connections.
HTTP method and endpoint
GET /protocols/nvme/subsystems/{subsystem.uuid}/hosts
Introduced in
ONTAP 9.6
Usage notes
Retrieves the NVMe subsystem hosts of an NVMe subsystem.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
subsystem_maps.*
Related ONTAP commands
vserver nvme subsystem map show -
vserver nvme subsystem show
Learn more
subsystem.uuid |
string |
path |
True |
The unique identifier of the NVMe subsystem. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[nvme_subsystem_host] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"dh_hmac_chap": {
"group_size": "string",
"hash_function": "string",
"mode": "bidirectional"
"io_queue": {
"count": 4,
"depth": 32
"nqn": "nqn.1992-01.example.com:string",
"priority": "string",
"subsystem": {
"name": "subsystem1",
"tls": {
"key_type": "configured"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
72090001 |
The NVMe subsystem does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
dh_hmac_chap
A container for the configuration of NVMe in-band authentication using the DH-HMAC-CHAP protocol for a host.
group_size |
string |
The Diffie-Hellman group size for NVMe in-band authentication. When property |
hash_function |
string |
The hash function for NVMe in-band authentication. When property |
mode |
string |
The expected NVMe in-band authentication mode for the host. This property is an indication of which secrets are configured for the host. When set to:
io_queue
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller.
count |
integer |
The number of I/O queue pairs. Absence of this property in GET implies property priority is set and platform and transport protocol specific values for I/O queue count is being used. Valid in GET only. |
depth |
integer |
The I/O queue depth. Absence of this property in GET implies property priority is set and platform and transport protocol specific values for I/O queue depth is being used. Valid in GET only. |
io_queue
count |
integer |
The number of I/O queue pairs. The default value is inherited from the owning NVMe subsystem. |
depth |
integer |
The I/O queue depth. The default value is inherited from the owning NVMe subsystem. |
subsystem
The NVMe subsystem to which the NVMe host has been provisioned.
_links |
name |
string |
The name of the NVMe subsystem. |
uuid |
string |
tls
A container for the configuration for NVMe/TCP-TLS transport session for the host.
key_type |
string |
The method by which the TLS pre-shared key (PSK) is configured for the host. Optional in POST. The values for property Possible values:
This property defaults to |
records
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
_links |
dh_hmac_chap |
A container for the configuration of NVMe in-band authentication using the DH-HMAC-CHAP protocol for a host. |
io_queue |
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller. |
nqn |
string |
The NVMe qualified name (NQN) used to identify the NVMe storage target. Not allowed in POST when the |
subsystem |
The NVMe subsystem to which the NVMe host has been provisioned. |
tls |
A container for the configuration for NVMe/TCP-TLS transport session for the host. |
nvme_subsystem_host
_links |
dh_hmac_chap |
io_queue |
nqn |
string |
The NVMe qualified name (NQN) used to identify the NVMe storage target. |
priority |
string |
The host priority setting allocates appropriate NVMe I/O queues (count and depth) for the host to submit I/O commands. Absence of this property in GET implies io_queue count and I/O queue depth are being used. |
subsystem |
tls |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
