REST API reference
Retrieve LUN map reporting nodes
Retrieves the nodes reporting the mapping for a LUN, which helps in understanding the current mapping state within your storage network.
HTTP method and endpoint
GET /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}/reporting-nodes
Introduced in
ONTAP 9.10
Usage notes
Retrieves LUN map reporting nodes.
  • lun mapping show
lun.uuid
string
path
True
The unique identifier of the LUN.
igroup.uuid
string
path
True
The unique identifier of the igroup.
uuid
string
query
False
Filter by uuid
name
string
query
False
Filter by name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[lun_map_reporting_node]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
        "node": {
      "igroup": {
      "lun": {
      "name": "node1",
      "uuid": "5ac8eb9c-4e32-dbaa-57ca-fb905976f54e"
Status: Default
ONTAP Error Response Codes
Error Code Description
5374875
The specified LUN does not exist or is not accessible to the caller.
5374878
The specified initiator group does not exist, is not accessible to the caller, or is not in the same SVM as the specified LUN.
5374922
The specified LUN map does not exist.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
node
self
self
igroup
The initiator group of the LUN map of the reporting node.
_links
_links
uuid
string
The unique identifier of the initiator group.
lun
The LUN of the LUN map of the reporting node.
_links
_links
uuid
string
A cluster node from which network paths to the LUN are advertised by ONTAP via the SAN protocols.
_links
_links
igroup
igroup
lun
lun
name
string
The name of the node.
Either uuid or name are required in POST.
uuid
string
The unique identifier of the node.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
