Retrieve LUN map reporting nodes
Retrieves information about nodes that report on LUN mappings. Use this endpoint to understand how your LUNs are mapped across different nodes in the system.
HTTP method and endpoint
GET /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}/reporting-nodes
Introduced in
ONTAP 9.10
Usage notes
Retrieves LUN map reporting nodes.
Related ONTAP commands
lun mapping show
lun.uuid |
string |
path |
True |
The unique identifier of the LUN. |
igroup.uuid |
string |
path |
True |
The unique identifier of the igroup. |
name |
string |
query |
False |
Filter by name |
uuid |
string |
query |
False |
Filter by uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[lun_map_reporting_node] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"node": {
"igroup": {
"lun": {
"name": "node1",
"uuid": "5ac8eb9c-4e32-dbaa-57ca-fb905976f54e"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374875 |
The specified LUN does not exist or is not accessible to the caller. |
5374878 |
The specified initiator group does not exist, is not accessible to the caller, or is not in the same SVM as the specified LUN. |
5374922 |
The specified LUN map does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
node |
self |
_links
self |
igroup
The initiator group of the LUN map of the reporting node.
_links |
uuid |
string |
The unique identifier of the initiator group. |
lun
The LUN of the LUN map of the reporting node.
_links |
uuid |
string |
A cluster node from which network paths to the LUN are advertised by ONTAP via the SAN protocols.
_links |
igroup |
The initiator group of the LUN map of the reporting node. |
lun |
The LUN of the LUN map of the reporting node. |
name |
string |
The name of the node. Either |
uuid |
string |
The unique identifier of the node. Either |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
