Retrieve LUN map reporting nodes
Retrieves the nodes associated with LUN map reporting, offering insight into the mapping configuration for storage management tasks.
HTTP method and endpoint
GET /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}/reporting-nodes
Introduced in
ONTAP 9.10
Usage notes
Retrieves LUN map reporting nodes.
Related ONTAP commands
lun mapping show
lun.uuid |
string |
path |
True |
The unique identifier of the LUN. |
igroup.uuid |
string |
path |
True |
The unique identifier of the igroup. |
uuid |
string |
query |
False |
Filter by uuid |
name |
string |
query |
False |
Filter by name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[lun_map_reporting_node] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"node": {
"igroup": {
"lun": {
"name": "node1",
"uuid": "5ac8eb9c-4e32-dbaa-57ca-fb905976f54e"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374875 |
The specified LUN does not exist or is not accessible to the caller. |
5374878 |
The specified initiator group does not exist, is not accessible to the caller, or is not in the same SVM as the specified LUN. |
5374922 |
The specified LUN map does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
node |
self |
_links
self |
igroup
The initiator group of the LUN map of the reporting node.
_links |
uuid |
string |
The unique identifier of the initiator group. |
lun
The LUN of the LUN map of the reporting node.
_links |
uuid |
string |
A cluster node from which network paths to the LUN are advertised by ONTAP via the SAN protocols.
_links |
igroup |
The initiator group of the LUN map of the reporting node. |
lun |
The LUN of the LUN map of the reporting node. |
name |
string |
The name of the node. Either |
uuid |
string |
The unique identifier of the node. Either |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
