Retrieve IPsec policies
Retrieves IPsec policies to view and manage the existing configuration of secure network connections. This is useful for maintaining and auditing the security settings of your ONTAP environment.
HTTP method and endpoint
GET /security/ipsec/policies
Introduced in
ONTAP 9.8
Usage notes
Retrieves the collection of IPsec policies.
Related ONTAP commands
security ipsec policy show
certificate.name |
string |
query |
False |
Filter by certificate.name
certificate.uuid |
string |
query |
False |
Filter by certificate.uuid
remote_identity |
string |
query |
False |
Filter by remote_identity |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
protocol |
string |
query |
False |
Filter by protocol |
scope |
string |
query |
False |
Filter by scope |
enabled |
boolean |
query |
False |
Filter by enabled |
authentication_method |
string |
query |
False |
Filter by authentication_method
ipspace.name |
string |
query |
False |
Filter by ipspace.name |
ipspace.uuid |
string |
query |
False |
Filter by ipspace.uuid |
local_identity |
string |
query |
False |
Filter by local_identity |
name |
string |
query |
False |
Filter by name |
remote_endpoint.address |
string |
query |
False |
Filter by remote_endpoint.address |
remote_endpoint.port |
string |
query |
False |
Filter by remote_endpoint.port |
remote_endpoint.family |
string |
query |
False |
Filter by remote_endpoint.family |
remote_endpoint.netmask |
string |
query |
False |
Filter by remote_endpoint.netmask |
local_endpoint.address |
string |
query |
False |
Filter by local_endpoint.address |
local_endpoint.port |
string |
query |
False |
Filter by local_endpoint.port |
local_endpoint.family |
string |
query |
False |
Filter by local_endpoint.family |
local_endpoint.netmask |
string |
query |
False |
Filter by local_endpoint.netmask |
uuid |
string |
query |
False |
Filter by uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
error |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"num_records": 1,
"records": [
"authentication_method": "string",
"certificate": {
"name": "cert1",
"ipspace": {
"name": "exchange",
"local_endpoint": {
"address": "10.10.10.7",
"family": "string",
"netmask": "24",
"port": "23"
"local_identity": "string",
"name": "string",
"protocol": "17",
"remote_endpoint": {
"family": "string",
"netmask": "24",
"port": "23"
"remote_identity": "string",
"scope": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
_links
self |
certificate
Certificate for the IPsec policy.
_links |
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
local_endpoint
Local endpoint for the IPsec policy.
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
port |
string |
Application port to be covered by the IPsec policy |
remote_endpoint
Remote endpoint for the IPsec policy.
address |
string |
family |
string |
IPv4 or IPv6 |
netmask |
string |
port |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
records
IPsec policy object.
string |
Authentication method for the IPsec policy. |
certificate |
Certificate for the IPsec policy. |
enabled |
boolean |
Indicates whether or not the policy is enabled. |
ipspace |
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input. |
local_endpoint |
Local endpoint for the IPsec policy. |
local_identity |
string |
Local Identity |
name |
string |
IPsec policy name. |
protocol |
string |
Lower layer protocol to be covered by the IPsec policy. |
remote_endpoint |
Remote endpoint for the IPsec policy. |
remote_identity |
string |
Remote Identity |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
svm |
uuid |
string |
Unique identifier of the IPsec policy. |
