Retrieve IPsec policies
Retrieves the collection of IPsec policies to view or manage the security configurations for encrypted network communication.
HTTP method and endpoint
GET /security/ipsec/policies
Introduced in
ONTAP 9.8
Related ONTAP commands
security ipsec policy show
remote_endpoint.family |
string |
query |
False |
Filter by remote_endpoint.family |
remote_endpoint.port |
string |
query |
False |
Filter by remote_endpoint.port |
remote_endpoint.netmask |
string |
query |
False |
Filter by remote_endpoint.netmask |
remote_endpoint.address |
string |
query |
False |
Filter by remote_endpoint.address |
enabled |
boolean |
query |
False |
Filter by enabled |
local_identity |
string |
query |
False |
Filter by local_identity |
ipspace.name |
string |
query |
False |
Filter by ipspace.name |
ipspace.uuid |
string |
query |
False |
Filter by ipspace.uuid |
name |
string |
query |
False |
Filter by name
action |
string |
query |
False |
Filter by action
protocol |
string |
query |
False |
Filter by protocol |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
certificate.name |
string |
query |
False |
Filter by certificate.name
certificate.uuid |
string |
query |
False |
Filter by certificate.uuid
authentication_method |
string |
query |
False |
Filter by authentication_method
uuid |
string |
query |
False |
Filter by uuid |
remote_identity |
string |
query |
False |
Filter by remote_identity |
ppk.identity |
string |
query |
False |
Filter by ppk.identity
local_endpoint.family |
string |
query |
False |
Filter by local_endpoint.family |
local_endpoint.port |
string |
query |
False |
Filter by local_endpoint.port |
local_endpoint.netmask |
string |
query |
False |
Filter by local_endpoint.netmask |
local_endpoint.address |
string |
query |
False |
Filter by local_endpoint.address |
scope |
string |
query |
False |
Filter by scope |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
error |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"message": "entry doesn't exist"
"num_records": 1,
"records": [
"action": "string",
"authentication_method": "string",
"certificate": {
"name": "string",
"ipspace": {
"name": "Default",
"local_endpoint": {
"address": "10.10.10.7",
"family": "string",
"netmask": "24",
"port": "23"
"local_identity": "string",
"name": "string",
"ppk": {
"identity": "string"
"protocol": "17",
"remote_endpoint": {
"family": "string",
"netmask": "24",
"port": "23"
"remote_identity": "string",
"scope": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
_links
self |
certificate
Certificate for the IPsec policy.
_links |
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
local_endpoint
Local endpoint for the IPsec policy.
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length. |
port |
string |
Application port to be covered by the IPsec policy |
ppk
Post-quantum pre-shared key information.
identity |
string |
Post-quantum pre-shared key identity. |
remote_endpoint
Remote endpoint for the IPsec policy.
address |
string |
family |
string |
IPv4 or IPv6 |
netmask |
string |
port |
string |
svm
_links |
name |
string |
uuid |
string |
records
IPsec policy object.
action |
string |
Action for the IPsec policy. |
string |
Authentication method for the IPsec policy. |
certificate |
Certificate for the IPsec policy. |
enabled |
boolean |
Indicates whether or not the policy is enabled. |
ipspace |
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input. |
local_endpoint |
Local endpoint for the IPsec policy. |
local_identity |
string |
Local Identity |
name |
string |
IPsec policy name. |
ppk |
Post-quantum pre-shared key information. |
protocol |
string |
Lower layer protocol to be covered by the IPsec policy. |
remote_endpoint |
Remote endpoint for the IPsec policy. |
remote_identity |
string |
Remote Identity |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
svm |
uuid |
string |
Unique identifier of the IPsec policy. |
returned_error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
