REST API reference
Retrieve IPsec policies
Accesses the collection of IPsec policies to review their configurations and settings.
HTTP method and endpoint
GET /security/ipsec/policies
Introduced in
ONTAP 9.8
Usage notes
Retrieves the collection of IPsec policies.
  • security ipsec policy show
scope
string
query
False
Filter by scope
remote_identity
string
query
False
Filter by remote_identity
certificate.uuid
string
query
False
Filter by certificate.uuid
  • Introduced in: 9.10
certificate.name
string
query
False
Filter by certificate.name
uuid
string
query
False
Filter by uuid
ppk.identity
string
query
False
Filter by ppk.identity
  • Introduced in: 9.17
  • maxLength: 64
  • minLength: 6
action
string
query
False
Filter by action
  • Introduced in: 9.15
remote_endpoint.port
string
query
False
Filter by remote_endpoint.port
remote_endpoint.netmask
string
query
False
Filter by remote_endpoint.netmask
remote_endpoint.family
string
query
False
Filter by remote_endpoint.family
remote_endpoint.address
string
query
False
Filter by remote_endpoint.address
local_identity
string
query
False
Filter by local_identity
enabled
boolean
query
False
Filter by enabled
authentication_method
string
query
False
Filter by authentication_method
name
string
query
False
Filter by name
  • maxLength: 64
  • minLength: 1
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
protocol
string
query
False
Filter by protocol
ipspace.name
string
query
False
Filter by ipspace.name
ipspace.uuid
string
query
False
Filter by ipspace.uuid
local_endpoint.port
string
query
False
Filter by local_endpoint.port
local_endpoint.netmask
string
query
False
Filter by local_endpoint.netmask
local_endpoint.family
string
query
False
Filter by local_endpoint.family
local_endpoint.address
string
query
False
Filter by local_endpoint.address
certificate_modify_keepsa
boolean
query
False
Filter by certificate_modify_keepsa
  • Introduced in: 9.18
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
error
error
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "message": "entry doesn't exist"
  "num_records": 1,
  "records": [
      "action": "string",
      "authentication_method": "string",
      "certificate": {
        "name": "string",
      "ipspace": {
        "name": "Default",
      "local_endpoint": {
        "address": "10.10.10.7",
        "family": "string",
        "netmask": "24",
        "port": "23"
      "local_identity": "string",
      "name": "string",
      "ppk": {
        "identity": "string"
      "protocol": "17",
      "remote_endpoint": {
        "family": "string",
        "netmask": "24",
        "port": "23"
      "remote_identity": "string",
      "scope": "string",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
self
certificate
Certificate for the IPsec policy.
_links
_links
name
string
Certificate name
uuid
string
Certificate UUID
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input.
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
local_endpoint
Local endpoint for the IPsec policy.
address
string
IPv4 or IPv6 address
family
string
IPv4 or IPv6
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length.
port
string
Application port to be covered by the IPsec policy
ppk
Post-quantum pre-shared key information.
identity
string
Post-quantum pre-shared key identity.
remote_endpoint
Remote endpoint for the IPsec policy.
address
string
family
string
IPv4 or IPv6
netmask
string
port
string
svm
_links
_links
name
string
uuid
string
records
IPsec policy object.
action
string
Action for the IPsec policy.
string
Authentication method for the IPsec policy.
certificate
certificate
boolean
Indicates whether old security associations are kept upon certificate modification.
enabled
boolean
Indicates whether or not the policy is enabled.
ipspace
ipspace
local_endpoint
local_endpoint
local_identity
string
Local Identity
name
string
IPsec policy name.
ppk
ppk
protocol
string
Lower layer protocol to be covered by the IPsec policy.
remote_endpoint
remote_endpoint
remote_identity
string
Remote Identity
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
svm
svm
uuid
string
Unique identifier of the IPsec policy.
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
