Retrieve key management key information for specified keys
Retrieves information about key management keys for specified key identifiers, which is useful for accessing specific details related to those keys in your security configurations.
HTTP method and endpoint
GET /security/key-managers/{security_key_manager.uuid}/keys/{node.uuid}/key-ids/{key_id}
Introduced in
ONTAP 9.11
Usage notes
Retrieves the key management keys information for the specified key_id.
Related ONTAP commands
security key-manager key query -key-id <key_id>
security_key_manager.uuid |
string |
path |
True |
Key manager UUID. |
node.uuid |
string |
path |
True |
Node UUID. |
key_id |
string |
path |
True |
Key identifier. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
crn |
string |
Cloud resource name. |
encryption_algorithm |
string |
Encryption algorithm for the key |
key_id |
string |
Key identifier. |
key_manager |
string |
Key manager key server managing the key. Indicates the external key server when external key manager is configured. |
key_server |
string |
External key server for key management. |
key_store |
string |
Security key manager configured for the given key manager UUID. Key manager keystore value can be onboard or external. |
key_store_type |
string |
Security key manager keystore type. Keystore type can be onboard, external, or supported cloud key manager. |
key_tag |
string |
Additional information associated with the key. |
key_type |
string |
Encryption Key type. |
key_user |
string |
SVM associated with the key. |
node |
policy |
string |
Key store policy. |
restored |
boolean |
Indicates whether the key is present locally on the node. |
"href": "/api/resourcelink"
"crn": "CRN=v1:bluemix:public:containers-kubernetes",
"encryption_algorithm": "XTS-AES-256",
"key_id": "00000000000000000100000000000123456789asdfghjklqwertyuio123456780000000000000090",
"key_manager": "keyserver1.local:5696",
"key_server": "keyserver1.com:5698",
"key_store": "string",
"key_store_type": "string",
"key_tag": "key#",
"key_type": "string",
"key_user": "vs1",
"node": {
"name": "node1",
"policy": "IBM_Key_Lore",
"restored": 1
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
