Retrieve key management key information for specified keys
Retrieves key management key information for specified keys to access details associated with each key_id. This is useful when managing or auditing security keys in your environment.
HTTP method and endpoint
GET /security/key-managers/{security_key_manager.uuid}/keys/{node.uuid}/key-ids/{key_id}
Introduced in
ONTAP 9.11
Usage notes
Retrieves the key management keys information for the specified key_id.
Related ONTAP commands
security key-manager key query -key-id <key_id> -
security key-manager key query -key-id <key_id> -node <node> -
security key-manager key query -key-id <key_id> -node <node> -key-manager <key_manager>
security_key_manager.uuid |
string |
path |
True |
Key manager UUID. |
node.uuid |
string |
path |
True |
Node UUID. |
key_id |
string |
path |
True |
Key identifier. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
crn |
string |
Cloud resource name. |
encryption_algorithm |
string |
Encryption algorithm for the key |
key_id |
string |
Key identifier. |
key_manager |
string |
Key manager key server managing the key. Indicates the external key server when external key manager is configured. |
key_server |
string |
External key server for key management. |
key_store |
string |
Security key manager configured for the given key manager UUID. Key manager keystore value can be onboard or external. |
key_store_type |
string |
Security key manager keystore type. Keystore type can be onboard, external, or supported cloud key manager. |
key_tag |
string |
Additional information associated with the key. |
key_type |
string |
Encryption Key type. |
key_user |
string |
SVM associated with the key. |
node |
policy |
string |
Key store policy. |
restored |
boolean |
Indicates whether the key is present locally on the node. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
security_key_manager |
Security key manager object reference. |
svm |
"href": "/api/resourcelink"
"crn": "CRN=v1:bluemix:public:containers-kubernetes",
"encryption_algorithm": "XTS-AES-256",
"key_id": "000000000000000002000000000001008963c9213194c59555c1bec8db3603c800000000",
"key_manager": "keyserver1.local:5696",
"key_server": "keyserver1.com:5698",
"key_store": "string",
"key_store_type": "string",
"key_tag": "key#",
"key_type": "string",
"key_user": "vs1",
"node": {
"name": "node1",
"policy": "IBM_Key_Lore",
"restored": 1,
"scope": "string",
"security_key_manager": {
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
_links |
uuid |
string |
Key manager UUID |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
