REST API reference
Retrieve key management key information for specified keys
Accesses the key management key details for specific keys, providing essential information for managing and securing key resources.
HTTP method and endpoint
GET /security/key-managers/{security_key_manager.uuid}/keys/{node.uuid}/key-ids/{key_id}
Introduced in
ONTAP 9.11
Usage notes
Retrieves the key management keys information for the specified key_id.
  • security key-manager key query -key-id <key_id>
string
path
True
Key manager UUID.
node.uuid
string
path
True
Node UUID.
key_id
string
path
True
Key identifier.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
crn
string
Cloud resource name.
encryption_algorithm
string
Encryption algorithm for the key
key_id
string
Key identifier.
key_manager
string
Key manager key server managing the key. Indicates the external key server when external key manager is configured.
key_server
string
External key server for key management.
key_store
string
Security key manager configured for the given key manager UUID. Key manager keystore value can be onboard or external.
key_store_type
string
Security key manager keystore type. Keystore type can be onboard, external, or supported cloud key manager.
key_tag
string
Additional information associated with the key.
key_type
string
Encryption Key type.
key_user
string
SVM associated with the key.
node
node
policy
string
Key store policy.
restored
boolean
Indicates whether the key is present locally on the node.
      "href": "/api/resourcelink"
  "crn": "CRN=v1:bluemix:public:containers-kubernetes",
  "encryption_algorithm": "XTS-AES-256",
  "key_id": "00000000000000000100000000000123456789asdfghjklqwertyuio123456780000000000000090",
  "key_manager": "keyserver1.local:5696",
  "key_server": "keyserver1.com:5698",
  "key_store": "string",
  "key_store_type": "string",
  "key_tag": "key#",
  "key_type": "string",
  "key_user": "vs1",
  "node": {
    "name": "node1",
  "policy": "IBM_Key_Lore",
  "restored": 1
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
self
node
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
