REST API reference
Retrieve the SSH server configuration for an SVM
Accesses the SSH server configuration for a specific SVM to review or manage SSH settings.
HTTP method and endpoint
GET /security/ssh/svms/{svm.uuid}
Introduced in
ONTAP 9.10
Usage notes
Retrieves the SSH server configuration for the specified SVM.
  • security ssh
svm.uuid
string
path
True
SVM UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
ciphers
array[string]
Ciphers for encrypting the data.
key_exchange_algorithms
array[string]
Key exchange algorithms.
mac_algorithms
array[string]
MAC algorithms.
max_authentication_retry_count
integer
Maximum authentication retries allowed before closing the connection.
svm
svm
SVM name and UUID for which the SSH server is configured.
      "href": "/api/resourcelink"
  "ciphers": [
    "aes256_ctr",
    "aes192_ctr",
    "aes128_ctr"
  "key_exchange_algorithms": [
    "diffie_hellman_group_exchange_sha256",
    "diffie_hellman_group14_sha1"
  "mac_algorithms": [
    "hmac_sha1",
    "hmac_sha2_512_etm"
  "svm": {
    "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
