Retrieve the SSH server configuration for an SVM
Retrieves the SSH server configuration for a specified SVM to review or manage its settings.
HTTP method and endpoint
GET /security/ssh/svms/{svm.uuid}
Introduced in
ONTAP 9.10
Related ONTAP commands
security ssh
svm.uuid |
string |
path |
True |
SVM UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
ciphers |
array[string] |
Ciphers for encrypting the data. |
key_exchange_algorithms |
array[string] |
Key exchange algorithms. |
mac_algorithms |
array[string] |
MAC algorithms. |
max_authentication_retry_count |
integer |
Maximum authentication retries allowed before closing the connection. |
svm |
SVM name and UUID for which the SSH server is configured. |
"href": "/api/resourcelink"
"ciphers": [
"aes256_ctr",
"aes192_ctr",
"aes128_ctr"
"key_exchange_algorithms": [
"diffie_hellman_group_exchange_sha256",
"diffie_hellman_group14_sha1"
"mac_algorithms": [
"hmac_sha1",
"hmac_sha2_512_etm"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
