REST API reference
Retrieve the SSH server configuration for an SVM
Retrieves the SSH server configuration for a specific data SVM to review or manage its settings.
HTTP method and endpoint
GET /security/ssh/svms/{svm.uuid}
Introduced in
ONTAP 9.10
Usage notes
Retrieves the SSH server configuration for the specified data SVM.
  • security ssh
svm.uuid
string
path
True
SVM UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
ciphers
array[string]
Ciphers for encrypting the data.
host_key_algorithms
array[string]
Host key algorithms. The host key algorithm 'ssh_ed25519' can be configured only in non-FIPS mode.
is_rsa_in_publickey_algorithms_enabled
boolean
Enables or disables the ssh-rsa signature scheme, which uses the SHA-1 hash algorithm, for RSA keys in public key algorithms. If this flag is false, older SSH implementations might fail to authenticate using RSA keys. This flag should be enabled only as a temporary measure until legacy SSH client implementations can be upgraded or reconfigured with another key type, for example: ECDSA.
key_exchange_algorithms
array[string]
Key exchange algorithms.
mac_algorithms
array[string]
MAC algorithms.
max_authentication_retry_count
integer
Maximum authentication retries allowed before closing the connection.
svm
svm
SVM name and UUID for which the SSH server is configured.
      "href": "/api/resourcelink"
  "ciphers": [
    "aes256_ctr",
    "aes192_ctr",
    "aes128_ctr"
  "host_key_algorithms": [
    "ecdsa_sha2_nistp256",
    "ssh_ed25519",
    "ssh_rsa"
  "key_exchange_algorithms": [
    "diffie_hellman_group_exchange_sha256",
    "ecdh_sha2_nistp256"
  "mac_algorithms": [
    "hmac_sha2_512",
    "hmac_sha2_512_etm"
  "svm": {
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
