Retrieve the SSH server configuration for all SVMs
Accesses the SSH server configuration for all SVMs, reviewing settings that manage secure shell access across your storage environment.
HTTP method and endpoint
GET /security/ssh/svms
Introduced in
ONTAP 9.10
Usage notes
Retrieves the SSH server configuration for all the SVMs.
Related ONTAP commands
security ssh
ciphers |
string |
query |
False |
Filter by ciphers |
key_exchange_algorithms |
string |
query |
False |
Filter by key_exchange_algorithms |
mac_algorithms |
string |
query |
False |
Filter by mac_algorithms |
max_authentication_retry_count |
integer |
query |
False |
Filter by max_authentication_retry_count
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[svm_ssh_server] |
"next": {
"href": "/api/resourcelink"
"records": [
"ciphers": [
"aes256_ctr",
"aes192_ctr",
"aes128_ctr"
"key_exchange_algorithms": [
"diffie_hellman_group_exchange_sha256",
"diffie_hellman_group14_sha1"
"mac_algorithms": [
"hmac_sha1",
"hmac_sha2_512_etm"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
SVM name and UUID for which the SSH server is configured.
_links |
name |
string |
The name of the SVM. |
uuid |
string |
svm_ssh_server
_links |
ciphers |
array[string] |
Ciphers for encrypting the data. |
array[string] |
Key exchange algorithms. |
mac_algorithms |
array[string] |
MAC algorithms. |
integer |
Maximum authentication retries allowed before closing the connection. |
svm |
SVM name and UUID for which the SSH server is configured. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
