Retrieve the SSH server configuration for all SVMs
Obtains the SSH server configuration for all storage virtual machines (SVMs), which helps you manage network security settings across your data environment.
HTTP method and endpoint
GET /security/ssh/svms
Introduced in
ONTAP 9.10
Usage notes
Retrieves the SSH server configuration for all the data SVMs.
Related ONTAP commands
security ssh
is_rsa_in_publickey_algorithms_enabled |
boolean |
query |
False |
Filter by is_rsa_in_publickey_algorithms_enabled
host_key_algorithms |
string |
query |
False |
Filter by host_key_algorithms
mac_algorithms |
string |
query |
False |
Filter by mac_algorithms |
ciphers |
string |
query |
False |
Filter by ciphers |
key_exchange_algorithms |
string |
query |
False |
Filter by key_exchange_algorithms |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
max_authentication_retry_count |
integer |
query |
False |
Filter by max_authentication_retry_count
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[svm_ssh_server] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"ciphers": [
"aes256_ctr",
"aes192_ctr",
"aes128_ctr"
"host_key_algorithms": [
"ecdsa_sha2_nistp256",
"ssh_ed25519",
"ssh_rsa"
"key_exchange_algorithms": [
"diffie_hellman_group_exchange_sha256",
"ecdh_sha2_nistp256"
"mac_algorithms": [
"hmac_sha2_512",
"hmac_sha2_512_etm"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
SVM name and UUID for which the SSH server is configured.
_links |
name |
string |
uuid |
string |
svm_ssh_server
_links |
ciphers |
array[string] |
Ciphers for encrypting the data. |
array[string] |
Host key algorithms. The host key algorithm 'ssh_ed25519' can be configured only in non-FIPS mode. |
boolean |
Enables or disables the ssh-rsa signature scheme, which uses the SHA-1 hash algorithm, for RSA keys in public key algorithms. If this flag is false, older SSH implementations might fail to authenticate using RSA keys. This flag should be enabled only as a temporary measure until legacy SSH client implementations can be upgraded or reconfigured with another key type, for example: ECDSA. |
array[string] |
Key exchange algorithms. |
mac_algorithms |
array[string] |
MAC algorithms. |
integer |
Maximum authentication retries allowed before closing the connection. |
svm |
SVM name and UUID for which the SSH server is configured. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
