REST API reference
Retrieve the SSH server configuration for all SVMs
GET /security/ssh/svms
Introduced In: 9.10
Retrieves the SSH server configuration for all the data SVMs.
  • security ssh
login_grace_time
integer
query
False
Filter by login_grace_time
  • Introduced in: 9.18
max_authentication_retry_count
integer
query
False
Filter by max_authentication_retry_count
  • Max value: 6
  • Min value: 2
is_rsa_in_publickey_algorithms_enabled
boolean
query
False
Filter by is_rsa_in_publickey_algorithms_enabled
  • Introduced in: 9.16
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
host_key_algorithms
string
query
False
Filter by host_key_algorithms
mac_algorithms
string
query
False
Filter by mac_algorithms
key_exchange_algorithms
string
query
False
Filter by key_exchange_algorithms
ciphers
string
query
False
Filter by ciphers
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[svm_ssh_server]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "ciphers": [
        "aes256_ctr",
        "aes192_ctr",
        "aes128_ctr"
      "host_key_algorithms": [
        "ecdsa_sha2_nistp256",
        "ssh_ed25519",
        "ssh_rsa",
        "rsa_sha2_256",
        "rsa_sha2_512"
      "key_exchange_algorithms": [
        "diffie_hellman_group_exchange_sha256",
        "ecdh_sha2_nistp256"
      "mac_algorithms": [
        "hmac_sha2_512",
        "hmac_sha2_512_etm"
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
SVM name and UUID for which the SSH server is configured.
_links
_links
name
string
uuid
string
svm_ssh_server
_links
_links
ciphers
array[string]
Ciphers for encrypting the data.
host_key_algorithms
array[string]
Host key algorithms. The host key algorithms 'ssh_ed25519' and 'ssh_rsa' can be configured only in non-FIPS mode.
boolean
Enables or disables the ssh-rsa signature scheme, which uses the SHA-1 hash algorithm, for RSA keys in public key algorithms. If this flag is false, older SSH implementations might fail to authenticate using RSA keys. This flag should be enabled only as a temporary measure until legacy SSH client implementations can be upgraded or reconfigured with another key type, for example: ECDSA.
array[string]
Key exchange algorithms.
login_grace_time
integer
The login grace time allowed for SSH connection request timeout.
mac_algorithms
array[string]
MAC algorithms.
integer
Maximum authentication retries allowed before closing the connection.
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
