Retrieve ongoing SnapMirror transfers for a relationship
Retrieves the list of ongoing SnapMirror transfers associated with a specific relationship. Use this information to monitor transfer progress and manage replication tasks effectively.
HTTP method and endpoint
GET /snapmirror/relationships/{relationship.uuid}/transfers
Introduced in
ONTAP 9.6
Usage notes
Retrieves the list of ongoing SnapMirror transfers for the specified relationship.
Related ONTAP commands
snapmirror show
Example
GET "/api/snapmirror/relationships/293baa53-e63d-11e8-bff1-005056a793dd/transfers"
relationship.uuid |
string |
path |
True |
Relationship UUID |
bytes_transferred |
integer |
query |
False |
Filter by bytes_transferred |
total_duration |
string |
query |
False |
Filter by total_duration
error_info.message |
string |
query |
False |
Filter by error_info.message
error_info.code |
integer |
query |
False |
Filter by error_info.code
uuid |
string |
query |
False |
Filter by uuid |
state |
string |
query |
False |
Filter by state |
checkpoint_size |
integer |
query |
False |
Filter by checkpoint_size |
snapshot |
string |
query |
False |
Filter by snapshot |
relationship.restore |
boolean |
query |
False |
Filter by relationship.restore |
relationship.destination.cluster.name |
string |
query |
False |
Filter by relationship.destination.cluster.name
relationship.destination.cluster.uuid |
string |
query |
False |
Filter by relationship.destination.cluster.uuid
relationship.destination.svm.uuid |
string |
query |
False |
Filter by relationship.destination.svm.uuid |
relationship.destination.svm.name |
string |
query |
False |
Filter by relationship.destination.svm.name |
relationship.destination.path |
string |
query |
False |
Filter by relationship.destination.path |
relationship.destination.uuid |
string |
query |
False |
Filter by relationship.destination.uuid
relationship.destination.consistency_group_volumes.name |
string |
query |
False |
Filter by relationship.destination.consistency_group_volumes.name
throttle |
integer |
query |
False |
Filter by throttle
end_time |
string |
query |
False |
Filter by end_time
archive_retrieval_priority |
string |
query |
False |
Filter by archive_retrieval_priority
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[snapmirror_transfer] |
"next": {
"href": "/api/resourcelink"
"records": [
"archive_retrieval_priority": "high",
"bytes_transferred": 0,
"checkpoint_size": 0,
"end_time": "2020-12-02T18:36:19-08:00",
"error_info": {
"code": 6620046,
"message": "Transfer aborted"
"relationship": {
"destination": {
"cluster": {
"name": "cluster1",
"consistency_group_volumes": [
"name": "volume1"
"path": "svm1:volume1",
"svm": {
"name": "svm1",
"uuid": "d2d7ceea-ab52-11e8-855e-00505682a4c7"
"snapshot": "string",
"state": "string",
"storage_efficiency_enabled": null,
"throttle": 0,
"total_duration": "PT28M41S",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
error_info
Error information for the transfer.
code |
integer |
Error code |
message |
string |
Error message |
files
Specifies a file or LUN consisting of a source_path and an optional destination_path. If not specified, the destination_path is the same as the source_path. File restore is not supported if the source_path or destination_path contains commas in its directory or file name.
destination_path |
string |
source_path |
string |
cluster
_links |
name |
string |
uuid |
string |
name |
string |
The name of the volume. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
snapmirror_endpoint
Endpoint of a SnapMirror relationship. For a GET request, the property "cluster" is populated when the endpoint is on a remote cluster. A POST request to create the destination SVM endpoint or to establish an SVM DR relationship must have the property "cluster" populated with the remote cluster details. A POST request to create the destination FlexVol volume, FlexGroup volume, Consistency Group, ONTAP S3 bucket and NON-ONTAP object-store endpoints can optionally specify the "cluster" property when the source SVM and the destination SVM are peered. A POST request to establish a SnapMirror relationship between the source endpoint and destination endpoint and when the source SVM and the destination SVM are not peered, must specify the "cluster" property for the remote endpoint.
cluster |
consistency_group_volumes |
array[consistency_group_volumes] |
Mandatory property for a Consistency Group endpoint. Specifies the list of FlexVol volumes for a Consistency Group. |
path |
string |
ONTAP FlexVol/FlexGroup - svm1:volume1 ONTAP SVM - svm1: ONTAP Consistency Group - svm1:/cg/cg_name ONTAP S3 - svm1:/bucket/bucket1 NON-ONTAP - objstore1:/objstore
svm |
uuid |
string |
UUID of the endpoint. Applicable for object store SnapMirror relationships only. |
relationship
destination |
restore |
boolean |
Is the relationship for restore? |
uuid |
string |
snapmirror_transfer
SnapMirror transfer information
_links |
string |
This is supported for transfer of restore relationship only. Priority level at which objects are restored from the archival storage. The value can be high, standard or low. The cloud provider's lowest priority will be used as the default. It is only supported for object store SnapMirror relationships. If the objects were not archived, the property will be ignored. |
bytes_transferred |
integer |
Bytes transferred |
checkpoint_size |
integer |
Amount of data transferred in bytes as recorded in the restart checkpoint. |
end_time |
string |
End time of the transfer. |
error_info |
Error information for the transfer. |
relationship |
snapshot |
string |
Name of Snapshot copy being transferred. |
state |
string |
Status of the transfer. Set PATCH state to "aborted" to abort the transfer. Set PATCH state to "hard_aborted" to abort the transfer and discard the restart checkpoint. |
throttle |
integer |
Throttle, in KBs per second. This "throttle" overrides the "throttle" set on the SnapMirror relationship or SnapMirror relationship's policy. If neither of these are set, defaults to 0, which is interpreted as unlimited. |
total_duration |
string |
Elapsed transfer time. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
